C9500-48Y-4C
Benoit34159
i intend to buy a C9500-48Y-4C switch.
I have 2 questions :
1/ the switch ship withs how many fans? Is there any empty slots to add some others modules?
2/ Can you give me a Cisco reference for a direct attach cable to connect my servers (DELL Powervault R630 and DELL Powervault R730xd. For each server, the network ports are rj45 ports 1gbit/s)?
Thanks or you help
Benoit
Giuseppe Larosa
Hello Benoit,
C9500-48Y4C: Cisco Catalyst 9500 Series high-performance switch with 48x 1/10/25G Gigabit Ethernet + 4x 40/100G Uplink
see the datasheet
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9500-series-switches/nb-06-cat9500-ser-data-sheet-cte-en.html
You have flexibility on the uplink optics but all you can do is to buy a second unit and to create an SVL like a VSS pair.
About FAN:
>> The switches also ship with up to five field-replaceable variable-speed fans. These have front-to-back airflow and can operate with up to one individual fan failure. The fan trays support fan-tray Online Insertion and Removal (OIR) and can support a maximum fan speed of up to 24,000 rpm.
some models support optional network modules but it shouldn't be the case of this model.
Hope to help
Giuseppe
