C9500-48Y4C Packets currently in SNMP process input queue
Exonix
we have several C9500-48Y4C, 16.9.4 and monitore them with SNMP. 20 days ago one switch stopped sending reqests to our monitoring tool. After a short research, I found that the SNMP input queue increases as soon as I restart SNMP and refresh the monitoring. Unfortunately, the debug did not show anything. How can I fix it?
Thank you!
a0-130#sh snmp
Chassis: CAT23XXXXX
94198719 SNMP packets input
    0 Bad SNMP version errors
    9887 Unknown community name
    0 Illegal operation for community name supplied
    0 Encoding errors
    3847698 Number of requested variables
    0 Number of altered variables
    2910201 Get-request PDUs
    936167 Get-next PDUs
    0 Set-request PDUs
    0 Input queue packet drops (Maximum queue size 1000)
94188610 SNMP packets output
    0 Too big errors (Maximum packet size 1500)
    0 No such name errors
    0 Bad values errors
    0 General errors
    94186985 Response PDUs
    0 Trap PDUs
Packets currently in SNMP process input queue: 16
SNMP global trap: disabled SNMP logging: disabled
Hello @Exonix ,
if the SNMP view does not help your only option is an IOS XE upgrade.
Hope to help
Giuseppe
15 Replies 15
Giuseppe Larosa
Hello @Exonix ,
this is likely a SW bug.
In the past I have seen the same issue on Catalyst 3650 or 3850.
post a show version of the affected switch to help in doing a bug search,
Hope to help
Giuseppe
Hello @Giuseppe Larosa,
yes, it looks like. We found this article CSCvr98368 , but the commands are not complete:
(config)#Snmp-server view entSensor excluded
% Incomplete command.
(config)#Snmp-server view entSensor excluded ?
excluded MIB family is excluded from the view
included MIB family is included in the view
It seems I have to enter something between "view entSensor", but what?
Thank you!
Hello @Exonix ,
when you define an SNMP view you provide a name for the view
so try the following:
snmp-server view TEST excluded entSensor
snmp-server view TEST included iso
snmp-server view TEST RO
snmp-server view TEST RW
if you can also use the SNMP MIB navigator to locate a MIB.
Note : here entSensor is the name of the MIB to be excluded not the name of the view, the config example provided in the bug page is wrong !
Hope to help
Giuseppe
Hello @Giuseppe Larosa  the lst command didn't work:
(config)#snmp-server view OMD iso included
(config)#snmp-server view OMD entSensorType excluded
(config)#snmp-server view OMD RO
(config)#snmp-server view OMD ?
  WORD  MIB view family name
Hello @Exonix ,
forget about the last command but consider the view a sort of ACL order of commands is very important
I would use
if you think at how the OID trees are built iso is much more near the root of OID tree.
Hope to help
Giuseppe
I tried both orders - the result is always the same:
#sh snmp view
OMD iso - included nonvolatile active
OMD entSensorType - excluded nonvolatile active
cac_view pimMIB - included read-only active
cac_view msdpMIB - included read-only active
maybe it's all about nonvolatile ? Other options are "read-only"
Hello @Exonix ,
I think it is fine now as SNMP view definition , do you see any improvement in the switch ?
What is important is to filter = exclude the offending MIB, in this way the switch will not try to answer to variabled in the MIB that is filtered.
Hope to help
Giuseppe
unfortunately, there are no improvements. Apparently, I need to find the offending MIB. But how to find?
@Giuseppe Larosa I've disabled entire hive - didn't help:
sh snmp view
OMD ciscoEntitySensorMIB - excluded nonvolatile active
Hello @Exonix ,
Hope to help
Giuseppe
firmware upgrade has helped
Mark Elsen
         - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz93302
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello @Mark Elsen ,
restart helps, but only for a few seconds.
 - You may have a go with the current advisory release :
            https://software.cisco.com/download/home/286319589/type/282046477/release/Amsterdam-17.3.3?catid=268438038
        check if that can help
  M.
       Beauty and terror
      Just keep going
       No feeling is final
