08-31-2021 12:49 AM
Hey All,
I have Cisco switch WS-C2960XR-48LPD-I and I would like to ask if it possible to increase total availbale PoE power by adding new power supplies? Current total PoE power is 370W. We have added PWR-C2-1025WAC= power supplies, which have 1025W, but total PoE power has not change.
Br,
Matej
08-31-2021 03:10 AM
Check Table 1.
M.
08-31-2021 03:30 AM
Thanks for the reply, we upgraded the default PWR-C2-640WAC power supply to PWR-C2-1025WAC, but the available PoE power reminas the same 370W. Is that the supposed behaviour?
08-31-2021 03:07 PM
PWR-C2-1025WAC - when you replace with new one, you should see more Power available,
to understand better post below output :
show version
show environ
show power inline
09-01-2021 02:02 AM
sho version:
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(5b)E, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Wed 14-Sep-16 06:29 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
cctv1-f2-bts01 uptime is 5 days, 1 hour, 5 minutes
System restarted at 07:51:45 UTC Fri Aug 27 2021
System image file is "flash:/c2960x-universalk9-mz.152-5b.E.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960XR-48LPD-I (APM86XXX) processor (revision N0) with 524288K bytes of memory.
Processor board ID FDO2032B0BQ
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
100 Gigabit Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:B0:E1:03:B8:80
Motherboard assembly number : 73-100634-03
Power supply part number : 341-0531-03
Motherboard serial number : FDO203307W1
Power supply serial number : DCB2026B61B
Model revision number : N0
Motherboard revision number : C0
Model number : WS-C2960XR-48LPD-I
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FDO203208KX
System serial number : FDO2032B0BQ
Top Assembly Part Number : 68-100311-02
Top Assembly Revision Number : B0
Version ID : V06
CLEI Code Number : CMMKF10ARF
Daughterboard revision number : A0
Hardware Board Revision Number : 0x21
Switch Ports Model SW Version SW Image
* 1 54 WS-C2960XR-48LPD-I 15.2(5b)E C2960X-UNIVERSALK9-M
2 54 WS-C2960XR-48LPD-I 15.2(5b)E C2960X-UNIVERSALK9-M
Switch 02
Switch Uptime : 5 days, 1 hour, 6 minutes
Base ethernet MAC Address : 00:B0:E1:03:C2:80
Motherboard serial number : FDO203307Z4
Power supply serial number : DCB2026B5AS
Daughterboard serial number : FDO203208Y6
System serial number : FDO2032B0C9
Top assembly part number : 68-100311-02
Top assembly revision number : B0
Version ID : V06
Configuration register is 0xF
show env power
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A PWR-C2-1025WAC LIT192906Y6 OK Good Good 250/775
1B PWR-C2-1025WAC DCB1943C2SY No Input Power Bad Bad 250/775
show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 0.0 370.0
2 370.0 0.0 370.0
09-01-2021 04:54 AM
this required Physical investigation first and fix the issue.
09-02-2021 03:10 AM
Sure it is an issue, but Unit 1 is good so should have higher available PoE power. Or could be causing issue that switches are in stack?
