C9500-48y4c Switch SFP interface is Down
zp_cai
Cisco IOS XE Software, Version 16.11.01
Switch#show interfaces twentyFiveGigE 1/0/29
TwentyFiveGigE1/0/29 is down, line protocol is down (notconnect)
Hardware is Twenty Five Gigabit Ethernet, address is cc7f.76a4.34bc (bia cc7f.76a4.34bc)
Description: TO_Xier-HJ-SW-F3-1_link
MTU 1500 bytes, BW 25000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is unknown
Fec is auto
Switch#show interfaces twentyFiveGigE 2/0/29 capabilities
TwentyFiveGigE2/0/29
Model: C9500-48Y4C
Type: unknown
Speed: 1000,10000,25000
Duplex: full
FEC: auto/off/cl74/cl108
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Unicast suppression: percentage(0-100)
Multicast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(off,on,desired)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(2p6q3t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
Diagnostic Monitoring: N/A
Breakout Support: not applicable
Using these SFP's on the C1000 is fine, but not when the C9500 and C1000 are interconnecting because the C9500 is not recognized. I can't confirm if it's my configuration or the device or module. Meanwhile, other interfaces on the C9500 have used the same module, but no problems.
The SFP type is compatible with the c9500 SFP- 10GBASE-SR
5 Replies 5
marce1000
 - What is the sfp-type used on the 9500 ? Check : https://tmgmatrix.cisco.com/?dr=81&npid=50 , also available in attachment.
 M.
balaji.bandi
Can you post both sides :
show interfaces twentyFiveGigE x/x/x trans
what SFP you using speed ? 10GB ? or 1GB or 25GB ?
BB
show interfaces twentyFiveGigE 1/0/13 capabilities
TwentyFiveGigE1/0/13
Model: C9500-48Y4C
Type: unknown
Duplex: full
Channel: yes
Fast Start: yes
tx-(2p6q3t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
PortSecure: yes
Dot1x: yes
Leo Laohoo
Reboot the 9500.
If the links go up it could, potentially, be CSCvs14641.
