2960X IOS upgrade Issues
sameerasripad
Hello All,
We are upgrading IOS of 2960X switches in our network. The IOS has been upgraded from 15.2 to 15.2(7)E4.
The upgradation is being failed when we try to upgrade the IOS of the devices with version ID - 01 and 03.
Could you please suggest or recommend a solution to upgrade the IOS successfully.
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FOC1828S5B9
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:5F:86:EF:76:80
Motherboard assembly number : 73-14187-04
Power supply part number : 341-0527-01
Motherboard serial number : FOC1819G32W
Power supply serial number : DCB1822K32W
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C2960X-48FPD-L
Daughterboard assembly number : 73-14200-03
Top Assembly Part Number : 800-38001-01
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : CMMLJ00ARA
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48FPD-L 15.2(2)E5 C2960X-UNIVERSALK9-M
8 Replies 8
Leo Laohoo
I have never heard of a malarkey like this.
If the upgrade failed, what is/are the error message(s).
Hello Leo,.
The switch resides in the loading state and no change after that.
Cold reboot (pull the power cable).
Hello Leo,
Even after multiple reboots, it doesn't work.
Console into the switch and reboot.
Post the entire failed boot-up process.
Hello Leo,
Please find the attached logs
Raise a TAC Case and organize for an RMA.
balaji.bandi
V01 and V02 hardware release as per i know, so it should not effect your upgrade process. as suggested, can you post ugrade process where it failed to understand and suggestion can be made accordingly.
BB
