C9500 / Port-Channel issue
suneq
Hi all,
We have a simple topology like this:
Check Point A =====   2 x Catalyst 9500 in Stackwise Virtual  ===== Check Point B
The Port-channel between 9500 and Check Point A is OK
The Port-channel between 9500 and Check Point B is NOK: the 2 ports of 9500 are stuck in "waiting to be aggregated"
I'm pretty sure that the configuration in the switch are correct because it works well with the Check Point A.
I think that the problem comes from the Check Point B configuration but I need a way to prove it to the Check Point guy.
Do you guys know any useful CLI commands ("show", "debug"...) that I can use to investigate further please?
Many thanks.
Reza Sharifi
"sh etherchannel detail" should show you a lot of details about the setup. Once you have that info, ask the FW guy to give you the output from their side.
Thanks for your advice.
Here is the output:
Catalyst 9500:
Group: 2
Group state = L2
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Te2/0/1
Port state = Up Mstr Assoc Not-in-Bndl
Channel group = 2 Mode = Active Gcchange = -
Port-channel = Po2 GC = - Pseudo port-channel = Po2
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Te2/0/1 SA bndl 32768 0x2 0x2 0x202 0xD
Partner's information:
Port Flags Priority Dev ID Age key Key Number State
Te2/0/1 SA 255 001c.7f6d.c95e 0s 0x0 0xF 0x2 0x5
Age of the port in the current state: 0d:00h:31m:43s
Port: Te2/0/2
Local information:
Te2/0/2 SA bndl 32768 0x2 0x2 0x203 0xD
Te2/0/2 SA 255 001c.7f6d.c95e 0s 0x0 0xF 0x1 0x5
Port-channels in the group:
Port-channel: Po2 (Primary Aggregator)
Age of the Port-channel = 0d:01h:27m:35s
Logical slot/port = 11/2 Number of ports = 2
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Te2/0/1 Active 0
0 00 Te2/0/2 Active 0
Time since last port bundled: 0d:00h:31m:43s Te2/0/1
Time since last port Un-bundled: 0d:00h:34m:18s Te2/0/2
Checkpoint:
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2 (0)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 200
Down Delay (ms): 200
802.3ad info
LACP rate: slow
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 00:1c:7f:6d:c9:5e
Active Aggregator Info:
Aggregator ID: 5
Number of ports: 2
Actor Key: 15
Partner Key: 2
Partner Mac Address: e4:1f:7b:a9:15:80
Slave Interface: eth1-03
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 3927
Permanent HW addr: 00:1c:7f:6d:c9:5e
Slave queue ID: 0
Aggregator ID: 5
Actor Churn State: none
Partner Churn State: churned
Actor Churned Count: 0
Partner Churned Count: 8
details actor lacp pdu:
system priority: 65535
system mac address: 00:1c:7f:6d:c9:5e
port key: 15
port priority: 255
port number: 1
port state: 13
details partner lacp pdu:
system priority: 32768
system mac address: e4:1f:7b:a9:15:80
oper key: 2
port priority: 32768
port number: 514
port state: 5
Slave Interface: eth1-04
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 9
Permanent HW addr: 00:1c:7f:6d:c9:5f
Slave queue ID: 0
Aggregator ID: 5
Actor Churned Count: 2
port key: 15
port priority: 255
port number: 2
port state: 13
oper key: 2
port number: 515
port state: 5
We captured the traffic and saw a lot of LACP packets between 2 devices but it seems that the negotiation never happened and the port-channel remained down/down (physical ports were up / down (not connect))
If we issued "no channel-group 2 mode active" on physical ports, the ports and Po went up.
If we used the "on" mode, the Po went up as well.
I really do not understand what's happening. This should be something really basic..
