Hello, we have a new Cisco WebEx training room device connected to a port on our C9300-48P switch. That switch port is an access port with "voice vlan 2" setup. The vlan 2 subnet is our voice traffic (172.30.14.0/24 subnet). When looking on wireshark when doing a packet capture on the port the device plugs into it appears to be getting DSCP CS4 markings, but our up stream router is set to apply QoS over our MPLS to DSCP EF traffic. Our Cisco phones are coming across as that so it works, but this device for some reason is not.
What I did on that port is the below QoS policy. However if I look at the trunk port on that switch as it goes to the router, I'm still seeing it as DSCP CS4. What am I missing here? I can verify with wireshark the 802.1Q tagging is ID 2 (thinking Vlan 2), but the DSCP is still showing CS4. Attaching a screenshot from wireshark of the trunk port to our ISR 4331 router.
Switch QoS Policy and mappings:
class-map match-any WebEx
match vlan 2
policy-map WebEx
class WebEx
set dscp ef
interface GigabitEthernet1/0/37
service-policy output WebEx
Show policy-map int gi1/0/37
Service-policy output: WebEx
Class-map: WebEx (match-any)
382177 packets
Match: vlan 2
QoS Set
dscp ef
Class-map: class-default (match-any)
2745 packets
Match: any
