C9500 Redundant power supply
I have a site with a C9500 and they recently received a second power supply, I see that they are swappable but can they install the second pwr supply or to they need to shut down the switch and is there any configuration needed.
2 Accepted Solutions
Reza Sharifi
The PSU is hot-swappable and you don't need to change the config or take down the switch. All you have to do is to insert it into the slot.
Now, just to be sure, I would still do it in a maintenace window.
Power Supply Slots
The switch has two power supply slots that accept AC and DC input power supplies. The power supply modules are field replaceable units (FRUs) and are hot-swappable. The chassis is delivered with one power supply pre-installed in the power supply slot. If only one power supply is ordered, then a blank cover is installed in the empty power supply slot, which must remain installed if a power supply is not installed.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/hardware/install/b_catalyst_9500_hig/9500_product-overview.html
Leo Laohoo
The power supplies are OIR.  I have replaced a few of them while the 9500 is operational.
No issue(s) reported.
5 Replies 5
Reza Sharifi
Power Supply Slots
Thanks! for the quick response.
Good luck!
Also, once installed and powered up, you should be able to verify both PSUs with the below command:
sh environment power
Leo Laohoo
