C9500 Stackwise virtual domain #
brannonsweet@cox.net
Frequent Visitor
Frequent Visitor
I have 2 Cisco C9500 24 ports switches configured and running in stackwise just fine. The problem is, I used the wrong Domain number.
Can  I change the stackwise virtual domain number of my existing stack from one number to another number, without braking the stack?
Reza Sharifi
Never done it, but domain number is an optional command. So, you should be able to change it in a maintenance window and reload the whole stack without breaking it.
Reza Sharifi
Frequent Visitor
Frequent Visitor
It worked fine without breaking the stack. A reboot was required as you suggested.  Thanks.
I'm glad to know it all worked well for you!
