Subinterfaces on Firepower 1010
elsa-mitchell
Visitor
I am migrating from ASA5506 firewalls to 1010s and am wondering if there is a way to configure subinterfaces on the 1010 from the command line interface (CLI). Using the same commands as the 5506s does not work, and I have only been able to find resources online to configure subinterfaces from a GUI interface. Thanks in advance for any advice or help.
Solved this issue. Just forgot to no switchport the ports.
FRP1010 is run FTD image or ASA?
MHM
It is running ASA image.
