11-19-2019 09:06 PM - edited 11-19-2019 09:34 PM
Hi there,
I've got Spectrum cable (Cadant CMTS), with a Netgear modem. Whenever I reboot my firewall, switch, or modem, I can't get an IP address until I connect the modem to the firewall (Ubiquiti USG) and then it grabs a public DHCP lease and will work over my Cisco configuration. These aren't layer 3 ports. No other ports are online with vlan 999. The only layer 3 interface is vlan1. I have no VLAN set on my firewall WAN/LAN ports so GigE0/24 should be fine. I click connect all day on my Ubiquiti firewall and it says "No internet connection" until physically connected to the modem and reboot modem/firewall. Once I get a lease, I can introduce the switch and stay connected.
The SFP fiber port is connected to a TP-LINK ethernet to media converter and I do this for lightning isolation between the coaxial modem and my firewall. (I've had everything fried 3 times so far.) I don't have any sort of DHCP snooping protection enabled as far as I can see, so not sure what's happening.
Anyone know what to look for?
Here's the relevant configs.
version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname core-sw-01 ! no aaa new-model clock timezone UTC -6 system mtu routing 1500 ! ip subnet-zero ip domain-name localdomain ip name-server 192.168.1.1 ! no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending lldp holdtime 60 ! interface GigabitEthernet0/24 description FIREWALL WAN LINK switchport access vlan 999 switchport mode access ! interface GigabitEthernet0/27 description FIBER UPLINK switchport access vlan 999 switchport mode access ! interface Vlan1 ip address 192.168.1.3 255.255.255.0 !
Switch info
Model number : WS-C3560G-24PS-S SFP Module assembly part number : 73-7757-03 SFP Module revision Number : A0 SFP Module serial number : CAT102325TB core-sw-01#show inventory NAME: "1", DESCR: "WS-C3560G-24PS" NAME: "GigabitEthernet0/27", DESCR: "1000BaseSX SFP" PID: , VID: , SN: AGM1116J86R
999 VLAN0999 active Gi0/24, Gi0/25, Gi0/27 1002 fddi-default act/unsup 1003 token-ring-default act/unsup 1004 fddinet-default act/unsup 1005 trnet-default act/unsup VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2 ---- ----- ---------- ----- ------ ------ -------- ---- -------- ------ ------ 1 enet 100001 1500 - - - - - 0 0 999 enet 100999 1500 - - - - - 0 0
I found this thread, and the poster concluded that some Cisco devices just don't support cable modems on access ports, but that doesn't make any sense?
https://community.cisco.com/t5/switching/cable-modem-not-passing-ip-over-vlan/td-p/2580418
Solved! Go to Solution.
11-20-2019 07:20 PM - edited 11-20-2019 07:21 PM
@balaji.bandi I don't think that was the issue, it was LLDP.
The Link Layer Discovery Protocol (LLDP) is a link layer protocol used by devices for advertising their identity, capabilities, and neighbors on a local area network.
More technical: Each device configured with LLDP sends periodic messages to the Slow Protocols multicast MAC address as specified by Std 802.3, 2000 Edition Annex 43B. The device sends the periodic messages on all physical interfaces enabled for LLDP transmission, and listens for LLDP messages on the same set on interfaces. Each LLDP message contains information identifying the source port as a connection endpoint identifier. It also contains at least one network address which can be used by an NMS to reach a management agent on the device (via the indicated source port).
This exposes the MAC address making the modem refuse DHCP to the firewall later on.
Solution
These interface settings (the port connected to the modem) resolve the issue.
interface GigabitEthernet0/27 description FIBER to MODEM switchport access vlan 999 switchport mode access no lldp transmit !!! THESE ARE THE OPTIONS I AM TALKING ABOUT no lldp receive !!! THESE ARE THE OPTIONS I AM TALKING ABOUT spanning-tree portfast
end
11-20-2019 12:24 AM
Another suggestion is since we are not sure what other products have capabilities.
if your provider not very interested in VLAN or Fancy, make it default VLAN 1 to access port save config and restart the switch and test.
Solution
end
11-21-2019 12:10 AM - edited 11-21-2019 12:12 AM
Hello
When I inInitially saw your OP I would have said more likley it was spanning-tree portfast not being enabled on the port?
11-21-2019 12:17 AM - edited 11-21-2019 12:18 AM
Oddly enough portfast had nothing to do with it, as I had portfast enabled initially and had disabled it, but had nothing with either config.
It was LLDP at the end of the day. I guess DOCCIS 3.0 Netgear modems do not play nice with LLDP.
