CAM Issue.
Robo123
Hi Team,
I have a Cisco WS-C3560 switch
wher i am getting the below Error
%PLATFORM_UCAST-6-PREFIX: One or more, more specific prefixes
Please suggest on the above .
8 Replies 8
Julio E. Moisa
Try to change the SDM template on your switch to get more IP space, first check your current SDM template
show sdm prefer
then
conf t
sdm prefer routing
write
reload  (to take effect)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Can you briefly explain about this error  if possible plz share ciso documents
You should check the TCAM table, using the following command:
sh platform tcam utilization
About the Cisco Reference:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750e_3560e/software/release/12-2_40_ex/release/notes/OL13929.html
Error Message    PLATFORM_UCAST-6-PREFIX: One or more, more specific prefixes could not
be programmed into TCAM and are being covered by a less specific prefix
Explanation    A more specific prefix could not be programmed into Ternary Content Addressable Memory (TCAM) and is covered by a less specific prefix. This could be a temporary condition. The output of the show platform ip unicast failed route privileged EXEC command lists the failed prefixes.
Hope it is useful
Hi julio,
As per document i can see there is no action  is required for the same. It means  its cosmetic and we can ignore
Yes, that is correct, it could be a temporal condition but should be good verify the current TCAM capacity, if you are using this switch for routing you could use the SDM template to assign better the resources for routing.
Thanks for the info
Please clarify routing templates  conf will resolve  the issue if routing  enabled in the same device
It will increase the IP address space on the device and focus the resources for routing, if this device is proccessing a lot of information for routing it should be an option to enable.
Also check this link:
https://supportforums.cisco.com/t5/lan-switching-and-routing/platform-ucast-6-prefix/td-p/1346455
If you are receving a lot of unicast log messages, it could be a bug, verify if your device and ios is on the list:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtg06347/?referring_site=bugquickviewredir
Sdm prefer routing  command is configured  already  but still getting the same error  continuously. As well checked the mentioned bug also but  the current  ios is not falling  in the same. Kindly  let me know  how can i proceed  further.
