we want upgrade our Catalyst4510R+E with 2 SUP8E from
cat4500es8-universalk9.SPA.03.03.02.XO.151-1.XO2.bin to
cat4500es8-universalk9.SPA.03.10.00.E.152-6.E.bin
Is this possible with the normal upgrade procedure: copy the new image to bootflash and slavebootflash then issue the boot system bootflash:...... command?
Hubert
Solved! Go to Solution.
<>Read the Release Notes carefully. Pay close attention to the ROMmon version requirement. It is stated in the Release Notes:
If you are upgrading to Cisco IOS XE Release 3.9.xE and plan to use VSS, you must upgrade your ROMMON to version 15.0(1r)SG10. Otherwise, you must upgrade your ROMMON to at least Version 15.0(1r)SG2.
Otherwise, the easiest way to upgrade the IOS is:
1. Copy the IOS into the primary supervisor card;
2. Copy the IOS into the secondary supervisor card;
3. Compare and verify the MD5 hash of the files against the value found in the Cisco website;
4. Verify the config-registry to be 0x2102;
5. Change the boot variable string;
6. Save the config; and
7. Reboot
7. Reboot
Thanks for the reply. Currently ROM 15.1(1r)SG5 is running. Do I have to upgrade the ROMMON?
this ist the output of sh module:
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1902L9M8
2 48 10/100/1000BaseT Premium POE E Series WS-X4748-RJ45V+E CAT1902L9UM
3 12 1000BaseX (SFP) WS-X4612-SFP-E JAE19370A9H
5 Supervisor
6 8 Sup 8-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP8-E CAT1902LA58
Mod Redundancy role Operating mode Redundancy status
5 Standby Supervisor SSO Disabled
6 Active Supervisor SSO Active
Am I right, that ROMMON 15.1(1r)SG5 will support the IOS?
5 Supervisor
Post the complete output to the command "sh version".
According to the 3.6.10E Release Notes, if you're not running VSS, then ROMmon upgrade is not required. Upgrade the ROMmon if running VSS.
Hi, here is the complete output from sh version:
xanthippe#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSALK9-M), Version 03.03.02.XO RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 19-Aug-14 02:17 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.1(1r)SG5
xanthippe uptime is 2 years, 26 weeks, 5 days, 7 hours, 4 minutes
Uptime for this control processor is 2 years, 26 weeks, 5 days, 7 hours, 6 minutes
System returned to ROM by SSO Switchover
System restarted at 06:45:41 CET Mon Mar 23 2015
Running default software
Host configuration file is "tftp://139.14.1.2/xanthippe-confg"
Jawa Revision 3, RadTrooper Revision 0x0.0x41, Conan Revision 0x1449
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP8-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4510R+E (P5040) processor (revision 2) with 4194304K bytes of physical memory.
Processor board ID FXS1851Q1JJ
P5040 CPU at 2.2GHz, Supervisor 8-E
Last reset from PowerUp
45 Virtual Ethernet interfaces
108 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
xanthippe#
Ok. Tomorrow I give it a try.
the upgrade works. Many thanks for your help.
