Showing results forĀ
Search instead forĀ
Did you mean:Ā
Campus network
roshanverg
Hello
can anyone tell  scalable design which meets the following requirement
two main locations are 3KM distance . Each department has 3 seperate buildings distance between buildings are 30M . There should be VPN access and security with a firewall as well as VLANS.
PLS provide a cabling solution according to cisco campus network guides.
nkarthikeyan
Level 11
Level 11
can u pls ellobarate the requirement. If my understanding is wrong
2 offices  say branch a and branch b having the distance of 3 KM... each offices has 3 buildings which is 30 m in range.
Between branches you can have the dart fiber connection as per the requirement.
Between the building (30 M range) either you can have the UTP/Multimode fiber connectivity .
