08-18-2023
09:30 AM
- last edited on
08-18-2023
10:41 AM
by
rupeshah
08-18-2023 12:09 PM
Hello @lkermode ,
a VRF is a routing table and is not a possible option as span source as noted by @Reza Sharifi you need to create a monitor session and to specify each source interface one by one in a list comma separated.
Be aware that if the number of source interfaces is high traffic can be dropped out of monitor destination port.
Hope to help
Giuseppe
08-19-2023 01:36 AM
Hello @lkermode,
you cannot directly span an "entire" VRF instance on your Nexus 93180YC-FX.
However, you could span the interfaces or VLANs attached to the VRF. This way, you can capture the traffic associated with that VRF !
08-18-2023 09:36 AM
We have two N9K routers on which several WAN circuits are terminated. We want to span all of these interfaces and send the flow to a Riverbed AppResponse. All of the interfaces are in a vrf wan and I am trying to get the flow from all the interfaces.
08-18-2023 12:03 PM
It appears that the choices are:
ethernet Ethernet IEEE 802.3z
port-channel Port Channel interface
sup-eth Ethernet Inband interface
So, I don't see an option to use a vrf.
08-18-2023 12:09 PM
Hello @lkermode ,
Hope to help
Giuseppe
09-22-2023 07:55 AM
Thanks for the reply and confirming my understanding.
08-19-2023 01:36 AM
Hello @lkermode,
