Same model 9200s showing different free space after upgrade
wesleyj
Just upgraded several of our C9200L-48T-4Xs to 17.9.4 after finding a bug in the 17.9.3 code. While the upgrade was successful, a couple are showing significantly different free space after the upgrade(less than 1gb).
gar-2-118-3r15-sw#dir
Directory of flash:/
8099 drwx 4096 Sep 21 2023 07:01:46 -05:00 .installer
8112 -rw- 2097152 Sep 21 2023 07:01:25 -05:00 nvram_config_bkup
8111 -rw- 2097152 Sep 21 2023 07:01:25 -05:00 nvram_config
8168 drwx 4096 Sep 21 2023 07:01:18 -05:00 .images
8126 -rw- 0 Sep 21 2023 07:00:34 -05:00 dope_hist
8113 -rw- 15116 Sep 21 2023 07:00:34 -05:00 rdope_out.txt
8114 -rw- 89 Sep 21 2023 07:00:31 -05:00 rdope.log
8116 -rw- 10536 Sep 21 2023 07:00:01 -05:00 vlan.dat
40506 drwx 4096 Sep 21 2023 07:00:01 -05:00 license_evlog
40481 drwx 4096 Sep 21 2023 06:59:50 -05:00 .prst_sync
8104 -rw- 137940 Sep 21 2023 06:59:00 -05:00 memleak.tcl
8100 -rw- 2133 Sep 21 2023 06:59:00 -05:00 boothelper.log
40503 drwx 4096 Sep 21 2023 06:58:56 -05:00 dc_profile_dir
8101 -rw- 1702 Sep 21 2023 06:58:36 -05:00 bootloader_evt_handle.log
8122 -rw- 372 Sep 21 2023 06:57:33 -05:00 lateshutdown.log
8103 -rw- 3303 Sep 21 2023 06:55:56 -05:00 boothelper.log.old
64769 drwx 4096 Sep 21 2023 06:53:34 -05:00 .rollback_timer
8187 -rw- 4908 Sep 21 2023 06:52:51 -05:00 packages.conf
8171 -rw- 4908 Sep 21 2023 06:49:40 -05:00 cat9k_lite_iosxe.17.09.04.SPA.conf
8177 -rw- 44250339 Sep 21 2023 06:49:37 -05:00 cat9k_lite-rpboot.17.09.04.SPA.pkg
8176 -rw- 14860288 Sep 21 2023 06:48:01 -05:00 cat9k_lite-webui.17.09.04.SPA.pkg
8175 -rw- 5636096 Sep 21 2023 06:48:01 -05:00 cat9k_lite-srdriver.17.09.04.SPA.pkg
8174 -rw- 406405120 Sep 21 2023 06:48:01 -05:00 cat9k_lite-rpbase.17.09.04.SPA.pkg
8155 -rw- 1261 Aug 17 2023 07:27:10 -05:00 Baltimore.ca
8154 -rw- 1606 Aug 17 2023 07:27:10 -05:00 StarfieldServicesRootCA.ca
8153 -rw- 1924 Aug 17 2023 07:27:10 -05:00 ISRGRootX1CrossSignDST.ca
8152 -rw- 1338 Aug 17 2023 07:27:10 -05:00 DigiCertGlobalRootCA.ca
8150 drwx 4096 Aug 17 2023 07:27:05 -05:00 .rommon_sync
8137 drwx 4096 Aug 17 2023 07:27:04 -05:00 fp_cc_crash
8136 drwx 4096 Aug 17 2023 07:27:01 -05:00 EDScisco
40484 drwx 4096 Aug 17 2023 07:27:01 -05:00 tech_support
8119 -rw- 1629 Aug 16 2023 10:25:52 -05:00 merge_config.txt
8107 drwx 4096 May 22 2022 10:29:01 -05:00 .dbpersist
16194 drwx 4096 May 22 2022 10:25:36 -05:00 Tbot
97153 drwx 4096 May 22 2022 10:25:30 -05:00 sys_report
8121 -rw- 5242880 May 22 2022 10:25:28 -05:00 ssd
8132 -rwx 0 Dec 16 2020 11:25:20 -06:00 mode_event_log
8130 drwx 4096 Dec 16 2020 11:25:20 -06:00 SHARED-IOX
8115 -rw- 128912 Dec 3 2020 11:56:59 -06:00 pnp-tech-discovery-summary
8106 -rw- 34 Dec 3 2020 11:56:56 -06:00 pnp-tech-time
8102 drwx 4096 Jul 19 2020 03:17:32 -05:00 core
8108 drwx 4096 Jul 19 2020 03:17:11 -05:00 onep
1956839424 bytes total (836366336 bytes free)
gar-2-118-5r15-sw#dir
16208 -rw- 2097152 Sep 21 2023 07:01:09 -05:00 nvram_config_bkup
16207 -rw- 2097152 Sep 21 2023 07:01:09 -05:00 nvram_config
16195 drwx 4096 Sep 21 2023 07:01:02 -05:00 .installer
72866 drwx 4096 Sep 21 2023 07:01:01 -05:00 .images
16222 -rw- 0 Sep 21 2023 07:00:35 -05:00 dope_hist
16209 -rw- 15116 Sep 21 2023 07:00:35 -05:00 rdope_out.txt
16210 -rw- 89 Sep 21 2023 07:00:32 -05:00 rdope.log
16214 -rw- 10536 Sep 21 2023 07:00:02 -05:00 vlan.dat
48578 drwx 4096 Sep 21 2023 07:00:02 -05:00 license_evlog
56673 drwx 4096 Sep 21 2023 06:59:51 -05:00 .prst_sync
16200 -rw- 137940 Sep 21 2023 06:59:01 -05:00 memleak.tcl
16196 -rw- 2133 Sep 21 2023 06:59:01 -05:00 boothelper.log
56695 drwx 4096 Sep 21 2023 06:58:57 -05:00 dc_profile_dir
16197 -rw- 1702 Sep 21 2023 06:58:37 -05:00 bootloader_evt_handle.log
16218 -rw- 372 Sep 21 2023 06:57:34 -05:00 lateshutdown.log
16199 -rw- 3303 Sep 21 2023 06:55:57 -05:00 boothelper.log.old
72865 drwx 4096 Sep 21 2023 06:53:34 -05:00 .rollback_timer
16256 -rw- 4908 Sep 21 2023 06:52:51 -05:00 packages.conf
16243 -rw- 4908 Sep 21 2023 06:49:40 -05:00 cat9k_lite_iosxe.17.09.04.SPA.conf
80963 -rw- 44250339 Sep 21 2023 06:49:37 -05:00 cat9k_lite-rpboot.17.09.04.SPA.pkg
80962 -rw- 14860288 Sep 21 2023 06:47:59 -05:00 cat9k_lite-webui.17.09.04.SPA.pkg
80961 -rw- 5636096 Sep 21 2023 06:47:59 -05:00 cat9k_lite-srdriver.17.09.04.SPA.pkg
72872 -rw- 406405120 Sep 21 2023 06:47:59 -05:00 cat9k_lite-rpbase.17.09.04.SPA.pkg
16236 -rw- 1261 Aug 17 2023 07:26:54 -05:00 Baltimore.ca
16235 -rw- 1606 Aug 17 2023 07:26:54 -05:00 StarfieldServicesRootCA.ca
16234 -rw- 1924 Aug 17 2023 07:26:54 -05:00 ISRGRootX1CrossSignDST.ca
16228 -rw- 1338 Aug 17 2023 07:26:54 -05:00 DigiCertGlobalRootCA.ca
32385 drwx 4096 Aug 17 2023 07:26:50 -05:00 .rommon_sync
24298 drwx 4096 Aug 17 2023 07:26:49 -05:00 fp_cc_crash
24297 drwx 4096 Aug 17 2023 07:26:46 -05:00 EDScisco
56676 drwx 4096 Aug 17 2023 07:26:45 -05:00 tech_support
16215 -rw- 1629 Aug 16 2023 10:25:51 -05:00 merge_config.txt
16203 drwx 4096 May 22 2022 10:29:26 -05:00 .dbpersist
11 drwx 4096 May 22 2022 10:25:35 -05:00 Tbot
16232 drwx 4096 May 22 2022 10:25:29 -05:00 sys_report
16217 -rw- 5242880 May 22 2022 10:25:27 -05:00 ssd
16224 -rwx 0 Dec 16 2020 11:25:20 -06:00 mode_event_log
24295 drwx 4096 Dec 16 2020 11:25:20 -06:00 SHARED-IOX
16211 -rw- 129351 Dec 3 2020 11:44:56 -06:00 pnp-tech-discovery-summary
16202 -rw- 34 Dec 3 2020 11:44:53 -06:00 pnp-tech-time
16198 drwx 4096 Jul 19 2020 06:13:45 -05:00 core
16204 drwx 4096 Jul 19 2020 06:13:23 -05:00 onep
1956839424 bytes total (1307496448 bytes free)
This is not a serious issue right now, but it will be later when we need to upgrade to a newer version of code. I did a "dir /recursive flash:" and did a diff on the output, comparing files sizes. While they weren't exactly the same, the difference is negligible. I can find nothing(logs, old files, etc.) to explain why there is such a discrepancy in remaining space. Does anyone have any ideas?
sphillips
Can you explain the bug you're referring too? We just updated to 17.9.3.
There was a power supply related problem. Basically, if the power supply had the serial number ARTxxxxx and was inserted into slot 1 a loss of power would cause the switch to fail into RONMON. If the same power supply was inserted into slot 2, no issues. 17.9.4 fixed this bug.
Interesting. Thank you for the answer.
Regarding your free space, did you remove all of your inactive files following that upgrade?
I did. As far as I can tell, there is no visible difference in the content of the file systems. A few files here and there are a little bigger here and there, but nothing significant.
