Can also a SPAN port passes normal traffic while it monitors other ports?
turbo_engine26
Level 4
Level 4
Hello All,
I would like to know if a SPAN (mirroring) port can also passes users' traffic. I know that its being busy monitoring those traffic but can it also work as normal access port. Is there a feature in the new IOS to configure a port to act both access and monitoring port in the same time?
Appreciate your help. :)
5 Replies 5
Aaron Harrison
Yes, you can use the 'ingress' keyword on the monitor destination command.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
SPAN ports that monitor traffic cannot forward packets. There is no feature that enables the span destination port to behave as a normal access port too. Please see the link below for more details.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_52_se/configuration/guide/3750scg/swspan.html#wp1036749
HTH,
Roopa
Thanks but what the ingress keyword that Aaron talked about does?
Thx
The "ingress" keyword in the monitor session is to monitor the incoming packets on the interface and to forward it to the destination interface.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_52_se/configuration/guide/3750scg/swspan.html#wp1260596
HTH,
Roopa
Hi Roopa
It's not.
the 'rx' 'tx' and 'both' keywords specify which direction of traffic is monitored.
'ingress' - well.. read the manual.
Mr Turbo_Engine26 - if in doubt, test it or google what is suggested.
Aaron
