Can I enable DHCP snooping without actually running DHCP? DAI + IPSG
issacgillngc
Hi All,
I'm looking at running dynamic ARP inspection (DAI) as well as IP Source Guard (IPSG) on our network.  I understand DAI and IPSG both utilize/reference the DHCP snooping database/table.  We don't utilize DHCP anywhere on this network, so is it possible to simply enable DHCP snooping globally on the switch(es) while not actually having a DHCP server configured thus not actually having any DHCP traffic on this network?
The switches in use are Nexus 9300 as well as Catalyst 9300.
Thanks for any/all info!
-Issac
issacgillngc
It appears my question was answered in a thread about ARP ACLs Applying ARP ACLs for DAI Filtering - Cisco Community at least from a DAI perspective.  IPSG apparently also allows for manual ip bindings on that front Cisco Nexus 9000 Series NX-OS Security Configuration Guide, Release 10.3(x) - Configuring IP Source Guard [Cisco Nexus 9000 Series Switches] - Cisco
issacgillngc
If anyone knows of a hole in the plan let me know, otherwise it appears I can use manual IP-MAC bindings for IPSG and ARP ACLs for DAI on our Nexus 9k switches.
issacgillngc
Unfortunately, the above DAI info doesn't seem to apply to Nexus 9300 switches - still looking for info if anyone happens to have a Nexus solution for DAI without dhcp + dhcp snooping for dynamic arp inspection
