Disable telnet and enable SSH
i need help to disable telnet and enable ssh on 3850 switch, aaa server not configred
Reza Sharifi
Under the vty lines just add ssh only.
line vty 0 4
 transport input ssh
 transport output ssh
line vty 5 15
 transport input ssh
You also need a IOS that support SSH which means you need "K9" in the image name.
Reza Sharifi
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
we have configured this command
line vty 0 4
 transport input ssh
line vty 5 15
 transport input ssh
but still access telnet
BTW, you might get a better response if your open a new question on your issue, rather than posting a reply to an eight year old question.  Also, often helpful to post the exact device and its IOS version (and feature/licenses) being used.
Assuming have console access, what happens if you config as:
line vty 5 15
transport input none
transport output none
Does telnet access still work?
