Can I get a layer 2 switch with at least 8 Fibre/SFP connections?
Ellerby01
I've checked Cisco's product documentation for Catalyst 2960's and can't find a switch that will allow me to connect multiple fibre optics, (multimode) either directly or via SFP.  Am I missing something or do I need to look at L3 devices to provide this capability.
Apart from uplink ports, are all 2960 series switches RJ45 only?
Matt
Reza Sharifi
2960s are all copper.  If you need Gig SFP ports, you can get a 3560X with 12 SFP ports or 24.
Here are the part numbers:
WS-C3750X-12S-S
WS-C3750X-24S-S
Don't forget the SFPs
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.pdf
Reza Sharifi
WS-C3750X-12S-S
WS-C3750X-24S-S
Thanks for your help Reza, looks like it will have to be an L3 device then.
jamescox3
One option could be to get stand alone fiber to copper media converters if you don't want get a layer 3 switch.
3550-12g
http://www.cisco.com/en/US/products/hw/switches/ps646/products_data_sheet09186a00800913d0.html
though it uses GBICs, not SFP.
Media converters as mentioned another idea, but that could another source of failure, if your bent on SFPs you could use coupler/converter cables.
