load interval questions
lkadlik
If you change the load interval on an interface will this improve traffic flow?
If you want to see the results do you need to be logged into the router or will an application like solar winds pick it up?
Thank you.
Lynne
shillings
Level 4
Level 4
The load interval is just the period for which the device is measuring statistics.
For example, if you enter the show interface command, you'll see the input and output rates. These rates are an average of the past 5 minutes traffic, not a snapshot of when you entered the command.
You can drop the time period down from 5mins to 30sec if you want to see a slightly more current average rate. Hope that makes sense
Do you need router access to see the result?
Or can an application like Solar winds pick up the change?
Thank you.
Yes, you need to be connected to the router to do "sh inte x/x" command to see the input and output rate.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
No.
As Reza posted, you only need to log on to the router to issue the show interface command. Tools that query the device using SNMP don't need to "log on", but they often need their own password for SNMP read-access and they might have to pass an ACL that allows their source IP.  Also, unsure load interval would have any impact on SNMP stats, load average might not be in the MIB.  If not, this isn't usually considered a problem as tools that query SNMP stats often can do their own analysis.
