Can i have two different vlans with a class C network?
elieibr01
Hi all,
I have been tasked to find a solution to a problem we have in one of the sites we just bought.
Here is the scenario:
We have a C class network over there, for the sake of this conversation, it will be 192.168.1.0/24. The network only has L3 switches. Long story short, we will be installing 20 new IP cams , and i would like to place them on a separate vlan for obvious reasons.
Here is what the Core has for config on the existing vlan :
Interface Vlan x
ip helper-address x.x.x.x.
My question is : can i create a vlan y with the same range? ( ie: 192.168.1.100 255.255.255.0)
Any information pointing to the right direction is greatly appreciated!
Thanks in advance for your help!
The short answer is no, if you try and put that ipaddress with mask on a new vlan interface the router will tell you you have a conflict.
If you are constrained to use the 192.168.1.0 network, then need to split it
eg 192.168.1.1 255.255.255.128 on one vlan and
192.168.1.129 255.255.255.128 on another vlan
chrbradf1
Thanks alot for the information, i will test this configuration and report back my results
Thank you very much chrbradf1 , that did the trick!
