Can I use Rapid-PVST and RSTP on the same network
Ethan and Mia
Hi all
May I have a question
Our network have more than 20 vlan
Core switch use Rapid-PVST
Access switch user RSTP
Are they can work together ?
thank for advance.
balaji.bandi
yes, they can exist in the network, you need to look at the model of the switch and IOS have any limitations.
but when Rapid-PVST able to meet the requirement, what is use case to have RSTP (bit old and legacy still required to 30-50 seconds to converge)
you can also look MST if you like, but Rapid is quicker in terms of STP timers and convergence.
BB
balaji.bandi
BB
Joseph W. Doherty
That's an "it depends" answer.
I believe it's possible in some cases; don't recall all the specifics.
Probably most likely is if the non rapid-PVST equipment only hosting one VLAN, if it's hosting multiple VLANs, wouldn't expect you to be able to use different links per VLAN (for load sharing purposes) on the non-Cisco equipment.
You could also consider shifting to MST.
