can network module C9500-NM-8X be used for C9500-48Y4C switch?
jw_2020
I am considering buying C9500-48Y4C as our new core switch. However, I cannot find the information in the data sheet regarding its network module information. I want to use network module C9500-NM-8X. I don't know if C9500-48Y4C supports this or not.
Thank you,
8 Replies 8
Reza Sharifi
Thank you Reza for your quick response. Does this mean I have to buy c9500-16x or c9500-40x if I my network only supports 1/10G uplink connections?
Thank you,
John
C9500-48Y4C - This Model it self designed to act as Core Switch in the network, and each port support multi gig capacity.
You do not need any uplink module - you can use standard port to connect to uplink ( personall done few, did not see any issue hee)
until you have any specific concern.
BB
Thank you Balaji. That will work for me.
Regarding the 48 ports in the C9500-48Y4C; are they SFP+ and not RJ-45?
Yes, that is correct. The c9500-16x and c9500-40x are the only 2 models that support this module. If you can elaborate on what you are trying to accomplish, maybe I can help with a solution.
Thanks Reza. Yes, I would like the make sure the switch can support 1/10G connection upper link without having to upgrade everything to 40G and with QSFP. However, as BB said, if I can simply use those 1/10G ports with regular SFP+ without using the network module at all for uplink connection, that will work for me as well.
That is correct. You can use any other ports.
Good Luck!
