Can not access management interface on Cisco 4510R
it.services
We have a new Cisco 4500R and I have put an IP address and mask on the management interface and even added an default route for the vrf mgmtVrf yet when I plug a PC on the same subnet into the management port or connect it to a switch in the vlan for that subnet I can not ping or telnet to the management port.
ip vrf mgmtVrf
interface FastEthernet1
ip address 10.11.12.45 255.255.255.0
 ip vrf forwarding mgmtVrf
speed auto
duplex auto
ip route vrf mgmtVrf 0.0.0.0 0.0.0.0 10.11.12.2
All the default vrf mgmtVrf are configured. Am I missing a step?
10 Replies 10
U mean even if u put the PC to fa1 we see in the config it is not working?
See response to Jon.
Jon Marshall
The fa1 one port is up/up ?
Can you post a "sh ip route vrf mgmtVrf"
Jon
Switch#sh ip route vrf mgmtVrf
Routing Table: mgmtVrf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 10.11.12.2 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.11.12.2
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.11.12.0/24 is directly connected, FastEthernet1
L        10.11.12.45/32 is directly connected, FastEthernet1
Switch#sh int fa1
FastEthernet1 is up, line protocol is up
PC directly connected to fa1 is configured with 10.11.12.2/24 and can not ping fa1 and can't ping PC from switch:
Switch#ping vrf mgmtVrf 10.11.12.2
Sending 5, 100-byte ICMP Echos to 10.11.12.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
The PC may have a firewall on it ? which would stop pinging from the switch but not the other way round.
What supervisor and IOS version does the switch have ?
Jon
Switch#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.05.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 17:02 by prod_rel_team
License Information for 'WS-X45-SUP7-E'
    License Level: lanbase   Type: Permanent
    Next reboot license Level: lanbase
No firewalls on the PC and I have tried a couple different PC's along with connecting to a switch.
Can you just confirm, is this a single supervisor setup or do you have two sups in the chassis ?
Jon
Single supervisor set up.
There is nothing wrong with your configuration as far as i can see. I will have a check for bugs but don't hold out too much hope.
Jon
Chad Thelen
Was there ever any solution to this? I'm running into the same issue with a new 4500X. Have the exact configuration as the initial post, and it can't ping its gateway.
