Bookmark
Subscribe
1705
Can not access property web interface on Cisco 3560X
jorge.vega
                   Hi, I configured a Switch Cisco 3560X with a basic configuraction, My problem is that when I access Web interface by http://X.X.X.X an login after the image that I attached.
I tried restore the default configuration, also tried with different navigator, chrome, Internet explorer, fireffox, safari, change laptop... and update the java client.
Can comeone help me?
Thanks in advance.
kluczak16
try https:// and a different browser or you can use CNA:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps5931/product_data_sheet0900aecd8068820a.html
Hopefully it will help.
I tried already with different browser and the same, no property access, also with CNA works fine but webinterface don´t works.
Thanks to all
Jan Rolny
Level 3
Level 3
Hello Jorge,
I would try to reinstall image. Seems that maybe some file are missing in http folder on flash: .
Also check your browser settings. JavaScripts enabled and popup window blocker and so on. also Check AntiVirus and FW if it is not blocking some content on your PC.
Here is example how you can reinstall image. This will overwrite your current image.
Switch# archive download-sw /overwrite tftp://198.30.20.19/c3560x-universal-tar.122-55.SE.tar
Please notice that you need TAR image format. There is http management included. If you will flash just bin image so there is not http included.
Best Regards,
Jan
