Can not apply IPv4 and Ipv6 ACL concurrently to control snmp access
Yi Fan XU
Hi All!
Recently I am trying to harden the switch and router snmp access.
But I realized that I can only apply one acl, either IPv4 acl or IPv6 acl.
Below are acl configuration.
access-list 12 permit 192.168.160.120
ipv6 access-list IPV6-SNMP-ACL
 deny ipv6 any any log
First I control access using access-list 12 without problem.
   snmp-server user username groupname v3 access  12
Then I control access using Ipv6 nacl. There is no problem to apply.
   snmp-server user username groupname v3 access  ipv6 IPV6-SNMP-ACL
But I do "sh run", I only see v6 access list applied.
Then i re-apply v4 access-list and do "sh run". This time I only see v4 access list applied.
Is this the limitation of IOS?
For information, router is running with c1900-universalk9-mz.SPA.151-4.M8.bin
switch is running with c3560e-universalk9-mz.150-2.SE6.bin
Thanks!
nkarthikeyan
Level 7
Level 7
You can try like this.
snmp-server user username groupname v3 access  ipv6 IPV6-SNMP-ACL 12
Karthik
nkarthikeyan
Level 7
Level 7
Karthik
