Can not Configure HSRP in cisco catalyst 3850-X series switch.
fozlarabbi
I hope you are all well!
I try to  configure HSRP in cisco catalyst 3850-X series switch, But I can't configure HSRP cause the command are not there.
This is the Software version installed on it...
Switch Ports Model SW Version SW Image Mode
1 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
So please anybody help me  how to configure HSRP.
Thanks & Regrads
Fozla Rabbi
Reza Sharifi
What is the output of "sh ver"?
Also, under the vlan interface where you are trying to configure HSRP, what is the output of "standby ?"
example:
config t
inter vlan 1
standby ?
Carlos Villagran
Hi!
HSRP in 3850 is supported till version 3.3.X so an update is necessary to any other version,  3.6.4 recommended. Also, at least IPBASE license is needed.
Refer to the following cisco official document for details:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/ip/configuration_guide/b_fhrp_3se_3850_cg/b_fhrp_3se_3850_cg_chapter_010.html
Hope it helps, best regards!
JC
Hi!
Please help me how to IOS Update  03.02.03.SE cat3k_caa-universalk9 to cat3k_caa-universalk9.SPA.03.06.04.E.152-2.E4.bin.
Please send me Procedure of IOS up-gradation.
Thanks & Regards
Fozlarabbi
Start looking at this section of the config guide.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3e/consolidated_guide/configuration_guide/b_consolidated_3850_3e_cg/b_consolidated_3850_3e_cg_chapter_01100011.html
Remember to use the correct file name for the release version you want
Alex
Regards, Alex. Please rate useful posts.
