09-17-2015 11:34 AM - edited 03-08-2019 01:50 AM
Hi, I can not see some trunk when using command show interface trunk in switch 6500. The output of show ip interface brief and show run interface gx/x are up and trunk configured. Anyone can give me some suggestion ? Thank you
Solved! Go to Solution.
09-17-2015 05:33 PM
HI,
Can you share the interface configuration? I hope you have configured switchport mode trunk on the interface.
what is the output do you see when you run the command:
show int trunk
show int X/x capability
show int x/x switchport
Inayath
09-18-2015 05:20 PM
There is the culprit the config of port-channel:-
interface GigabitEthernet6/6
switchport
switchport access vlan 3
switchport trunk allowed vlan 9
channel-group 9 mode active >>>> When you configure this command the port goes into the PO hence you dont see this under the show int trunk command were as this will be not represented as Po9 under the show int trunk.
Inayath
***************Please mark the thread as answered if this has resolved the query and rate all usefull posts plz************
09-17-2015 05:33 PM
HI,
show int trunk
Inayath
09-18-2015 07:38 AM
Thanks for your reply. Now I noticed the difference between port that show trunk and not show trunk when I use command show run int gx/y. Please see below. The first one show trunk and second does not. Do you think if the reason is using channel-group ?
interface GigabitEthernet5/5
switchport
switchport trunk allowed vlan 3
spanning-tree portfast
switchport
09-18-2015 05:20 PM
switchport
Inayath
09-17-2015 09:58 PM
Try show int Gix/y switchport instead
09-18-2015 12:30 AM
Hello
Are you using CatIos by any chance?
try
show trunk
res
paul
