Can output drops on a switch cause input/output errors on a server interface?
Blackschwanzer
Hello.
A Unix server, directly connected to a int GigabitEthernet13/41 on a Cisco switch, is displaying RX and TX errors (hundreds of thousands of them).
On the switch int GigabitEthernet13/41, there are no errors of any kind (counters cleared +1 year ago), but there are Total output drops: 13969996.
Is there any possibility that these output drops could somehow cause input/output errors on the server?
The cabling and server's NIC was replaced, but the errors on the server interface remain.
Thank you
Here's the output:
SWITCH#sh int GigabitEthernet13/41
GigabitEthernet13/41 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0111.843e.abc8 (bia 0111.843e.abc8)
Description: xxxx
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 245/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:10, output 00:00:17, output hang never
Last clearing of "show interface" counters 1y13w
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 13969996
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 3000 bits/sec, 6 packets/sec
243921725 packets input, 85974891572 bytes, 0 no buffer
Received 851739 broadcasts (524765 multicasts)
0 watchdog, 0 multicast, 0 pause input
338112958 packets output, 56521487590 bytes, 0 underruns
6984998 output errors, 0 collisions, 0 interface resets
5 Replies 5
Leo Laohoo
Kindly post the complete output to the command "sh int Gi 13/41".
Here's the output:
Description: xxxx
Clock mode is auto
@Blackschwanzer wrote:
reliability 245/255
Thanks.  The output is very helpful.
The output error is caused by a Layer 1 issue.  The value (above) should always be "255/255".  Any other value is always indicative of a cable issue.
Thank you, Leo.
