Can SFP-10G-LR work with MM fiber cable?
mohammad saeed
Level 5
Level 5
Hi All
I have SFP LR type in core(X2-10G-LR) side and access switch side (SFP-10G-LR) but the fiber cable is MM om3.. can work with this case?
Reza Sharifi
You need a single mode fiber cable to connect them.
link
https://www.fs.com/products/12285.html
So will not work?
No, the optics are LR, so the cable needs to be single mode.
If you change the optics to SR than you can use multimode.
