3850X throughput issues
Cybervex3
Level 2
Level 2
Hey all
I am having a problem with a 3850-24XS. All traffic stops for 3 pings then returns to normal. Running a constant ping from multiple endpoints on trunk connected switches to multiple ports reveals 3 ping timeouts every 5 - 45 minutes resulting in a disruption of RDP session, SSH sessions, etc.
There is nothing in the logs. Everything was working fine for the last 6 months until yesterday.  No changes were made to the switch in the last week.
Any tips on which debugging I can turn on to capture the problem?
version 16.8
no service pad
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname WK_ToR
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5
no aaa new-model
switch 1 provision ws-c3850-24xs
ip routing
ip domain name p.local
cpp system-default
crypto pki trustpoint TP-self-signed-88678622
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-88678622
 revocation-check none
 rsakeypair TP-self-signed-88678622
crypto pki certificate chain TP-self-signed-88678622
 certificate self-signed 01
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
username jwadmin privilege 15 password 7
redundancy
 mode sso
class-map match-any system-cpp-police-topology-control
  description Topology control
class-map match-any system-cpp-police-sw-forward
  description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
  description EWLC control, EWLC data
class-map match-any system-cpp-police-sys-data
  description Learning cache ovfl, Crypto Control, Exception, EGR Exception, NFL SAMPLED DATA, Gold Pkt, RPF Failed
class-map match-any system-cpp-police-punt-webauth
  description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
  description L2 LVX control packets
class-map match-any system-cpp-police-forus
  description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
  description MCAST END STATION
  description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
  description L2 control
class-map match-any system-cpp-police-dot1x-auth
  description DOT1X Auth
class-map match-any system-cpp-police-data
  description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
  description Stackwise Virtual
class-map match-any system-cpp-police-control-low-priority
  description General punt
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
  description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
policy-map system-cpp-policy
 class system-cpp-police-data
 class system-cpp-police-sys-data
 class system-cpp-police-sw-forward
 class system-cpp-police-multicast
 class system-cpp-police-multicast-end-station
 class system-cpp-police-punt-webauth
 class system-cpp-police-l2-control
 class system-cpp-police-stackwise-virt-control
 class system-cpp-police-routing-control
 class system-cpp-police-control-low-priority
 class system-cpp-police-l2lvx-control
 class system-cpp-police-topology-control
 class system-cpp-police-dot1x-auth
 class system-cpp-police-protocol-snooping
 class system-cpp-police-dhcp-snooping
 class system-cpp-police-forus
 class system-cpp-default
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 10.7.0.40 255.255.0.0
 speed 1000
 negotiation auto
interface TenGigabitEthernet1/0/1
 no switchport
 ip address 10.1.0.2 255.255.254.0
interface TenGigabitEthernet1/0/2
 description IP_Phones_on_VLAN11
 switchport trunk allowed vlan 11
 switchport mode trunk
interface TenGigabitEthernet1/0/3
 description ESXi1
 switchport trunk allowed vlan 102,104,118
interface TenGigabitEthernet1/0/4
 description ESXi1
interface TenGigabitEthernet1/0/5
 description ESXi2
interface TenGigabitEthernet1/0/6
 description ESXi2
interface TenGigabitEthernet1/0/7
 description ESXi3
interface TenGigabitEthernet1/0/8
 description ESXi3
interface TenGigabitEthernet1/0/9
 description NH-JBOD-01_10G
 switchport access vlan 104
 spanning-tree portfast
interface TenGigabitEthernet1/0/10
interface TenGigabitEthernet1/0/11
 description NH-JBOD-02_10G
interface TenGigabitEthernet1/0/12
interface TenGigabitEthernet1/0/13
interface TenGigabitEthernet1/0/14
interface TenGigabitEthernet1/0/15
interface TenGigabitEthernet1/0/16
interface TenGigabitEthernet1/0/17
interface TenGigabitEthernet1/0/18
interface TenGigabitEthernet1/0/19
interface TenGigabitEthernet1/0/20
interface TenGigabitEthernet1/0/21
 description WK_ToR TO WK-East-01
 switchport trunk allowed vlan 11,102,106,108,110,112
interface TenGigabitEthernet1/0/22
 description WK_ToR TO WK-Copy-01
 switchport trunk allowed vlan 10,11,102,106,108,110,112,114
interface TenGigabitEthernet1/0/23
 description WK-ToR TO WK-SVR-02
 switchport trunk allowed vlan 11,102,104,106,108,110,112,114,116
interface TenGigabitEthernet1/0/24
 description WK-ToR TO WK-SVR-01
#####Remove ghost interfaces.
interface Vlan1
 no ip address
 shutdown
interface Vlan11
 no ip address
 ip helper-address 10.11.0.2
interface Vlan102
 description DHCP_Clients
 ip address 10.1.2.1 255.255.254.0
 ip helper-address 10.1.4.2
interface Vlan104
 description Servers
 ip address 10.1.4.1 255.255.254.0
interface Vlan106
 description Network-Printers
 ip address 10.1.6.1 255.255.254.0
interface Vlan108
 description PME_WiFi
 ip address 10.1.8.1 255.255.254.0
interface Vlan110
 description PME_Guest_WiFi
 ip address 10.1.10.1 255.255.254.0
interface Vlan112
 ip address 10.1.12.1 255.255.254.0
interface Vlan114
 description MISC-Machinery
 ip address 10.1.14.1 255.255.254.0
interface Vlan116
 description MGMT-VMware
 ip address 10.1.16.1 255.255.254.0
interface Vlan118
 description DMZ
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.1.0.1
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 10.10.1.1
ip ssh logging events
ip ssh version 2
control-plane
 service-policy input system-cpp-policy
line con 0
 exec-timeout 120 0
 logging synchronous
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 session-timeout 120
 exec-timeout 960 0
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 session-timeout 120
 exec-timeout 960 0
 logging synchronous
 login local
 transport input ssh
mac address-table notification mac-move
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
5 Replies 5
Reza Sharifi
Have you checked the CPU?
What is the output of
sh processes cpu | exclude 0.00
Also, see if "sh processes cpu history" can correlate with when the ping loss happens.
WK_ToR#sh processes cpu | exclude 0.00
CPU utilization for five seconds: 3%/0%; one minute: 2%; five minutes: 2%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   9    14793048     1302971      11353  0.87%  0.30%  0.23%   0 Check heaps
  79     4833389    26968325        179  0.07%  0.07%  0.07%   0 IOSD ipc task
 123     1710901    26309162         65  0.07%  0.07%  0.07%   0 IOSXE-RP Punt Se
 151      408508      750995        543  0.15%  0.03%  0.02%   0 NGWC L2M
 197     4822089   100625837         47  0.07%  0.07%  0.07%   0 VRRS Main thread
 217     6272981   200137135         31  0.07%  0.08%  0.07%   0 IPAM Manager
 220     5704075   200137127         28  0.07%  0.07%  0.07%   0 IP ARP Retry Age
 221     4256349    19530621        217  0.23%  0.26%  0.26%   0 IP Input
 239    12878601    44498518        289  0.23%  0.21%  0.23%   0 Spanning Tree
 340     4792139   100625671         47  0.07%  0.08%  0.08%   0 MMA DB TIMER
 530     2679650    32178097         83  0.07%  0.04%  0.02%   0 ONEP Network Ele
Funny.  It happened as I was typing the 'sh proc cpu history' so the the 60 second chart would show it.
WK_ToR#sh proc cpu history
          11111
      333300000222222222244444222225555566666555554444455555222223
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10     *****                    ***************     *****
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
                                 1               11           1
      664445644443754444864443486044674434474444411444558744441444
  100
   90
   80
   70
   60
   50
   40
   30
   20
   10 **   **     **    **     ***  **     *     **   ****    *
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
CPU looks very good with very little utilization. I did not see any specific bug case that could be associated with this but you may want to open a ticket with TAC as they may have a history on this.
While looking through the debug commands I used 'debug ethernet cfm error'.
Not 30 seconds later, Lucky me!, the switch did another timeout cycle. Not long enough to completely disconnect my SSH, only enough so that the session was unresponsive for a few seconds and leaving me with messages
*Nov 6 17:47:13.580: CFM-ERR: UTIL: Failed to find port for HWIDB Vlan106
*Nov 6 17:47:13.603: CFM-ERR: UTIL: Failed to find port for HWIDB Vlan112
*Nov 6 17:47:13.630: CFM-ERR: UTIL: Failed to find port for HWIDB Vlan102
*Nov 6 17:47:13.634: CFM-ERR: UTIL: Failed to find port for HWIDB Vlan11
