Bookmark
Subscribe
3553
can sfp module used for 10gb interface on cisco router 3945
krishna das
kindly tell me,
2 Accepted Solutions
Thanks for your replay.
I have cisco router 3945 and 4 interface port and sfp port also.
is it possible to add 10gb sfp module to this router I here attached image file of this router. please go through on it and replay me please.
Hi Krishna,
Unfortunately i don't think 10 Gbps SFP is compatible with 3945 series routers.
Check out the compatible matrix for 10g SFP
As per Cisco 3945 compatible sheet shared earlier maximum SFP limit is 1 Gbps.
Hope it Helps..
-GI
Rate if it Helps
Hi Ganeesh,
Thank you so much for your immediate replay.
Hi Krishna,
If you are happy with response, it would be good you can mark this thread has answered so that others can be benefitted.
-GI
5 Replies 5
Ganesh Hariharan
kindly tell me,
Hi Krishna,
What SFP model are you talking , do you have the part number ?
Check out the SFP supported on Cisco 3945
Hope it Helps.
-GI
Rate if it Helpss
Hi Krishna,
Hope it Helps..
-GI
Rate if it Helps
Hi Ganeesh,
Hi Ganeesh,
Hi Krishna,
-GI
