Can't access web-interface on my switch(cisco sg250-08) Linux Debian
mxl
Hello! Please help with this question! Can't access web-interface on my network switch(cisco sg250-08) on linux debian 11(bullseye). I can not find the IP address from my network communicator to connect to it through the web. //192.168.1.254- not responded.
Max
balaji.bandi
First basic requirement, what is your Linux IP address, and are you able to ping the switch IP address ?
BB
27 Replies 27
balaji.bandi
BB
Hello! my  Linux ip is 127.0.1.1
Max
That is Loopback address (with that you are not  going to achive what you like to do)
First configure your Linux IP address either Manually or DHCP, then ping to 192.168.1.254 - if that success only -  then try GUI.
BB
if I understood you correctly, my Internet is working now through my communicator(cisco sg250-08) to my computer.
ping: http://192.168.1.254: Name or service not known
Max
the computer mean your Linux (debian)
post below out put from Linux computer :
Go to Linux shell
ifconfig (post complete output)
traceroute 8.8.8.8  (post complete output)
BB
ifconfig
alternative -- ip a
ok
traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
20 * dns.google (8.8.8.8) 17.518 ms 15.727 ms
Max
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
Max
I sure you getting the IP address from ISP Roputer - 100.125.0.1
The Switch acting as Layer 2 only, you need to configure, you need to in that subnet:
Configuring Your Switch Using the Web-based Interface
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/250_/2_5_7/Admin_guide/tesla-250-ag/get-to-know-your-switch.html
BB
Thanks for the help, but I really don't know what to do. When I bought the communicator, I thought that I would turn it on and would configure it via the web, but no ...
Max
Not sure what the condition of the switch, Looks like you ignore the right document i have provided and also mentioned the section to look.
here is the steps :
1. rather than google, focus on the document provided with the section.
2. remove Internet connection from the switch.
3. configure your Debian Linux same range IP
4. then you can able to access the switch to configure.
5. change the VLAN 1 IP address from 192.168.1.X to 100.125.0.X (x is one of the free IP in the subnet and save config.
6. connect back your Internet connection.
7. debian Linxu make DHCP, and you should be able to ping 100.125.0.X IP before you access GUI of the switch.
BB
I really appreciate your help! I understand more now.
Max
Sure we are here to help each other where we can, let me if that resolve your issue, if no further help required mark as solution, any further input required please post more information, so happy to assists where we can.
BB
Hello! After complex manipulations with the keyboard and after I disconnected the Internet wire from the communicator, I managed to enter the web interface, but again I cannot enter the web interface! Am I doing something wrong? Could you tell us more about step number 3! Thank you!
Max
this is if the switch is in the default IP address ? have you changed this?  if you have changed to whatever IP you should in the same range of IP to get GUI access, also make sure you set up the default gateway in switch towards ISP router. ( disable any DHCP / other settings which not required in switch)
make sure you save and commit the confg.
BB
