Can't access web-interface on my switch(cisco sg250-08) Linux Debian
mxl
Hello! Please help with this question! Can't access web-interface on my network switch(cisco sg250-08) on linux debian 11(bullseye). I can not find the IP address from my network communicator to connect to it through the web. //192.168.1.254- not responded.
Max
27 Replies 27
@balaji.bandi wrote:
3. configure your Debian Linux same range IP
this is if the switch is in the default IP address ? have you changed this?  if you have changed to whatever IP you should in the same range of IP to get GUI access, also make sure you set up the default gateway in switch towards ISP router. ( disable any DHCP / other settings which not required in switch)
make sure you save and commit the confg.
Thank you for your help! I logged into the web interface)) And I have disabled dhcp. But now I'm inserting a wire with the internet, now I don't have an internet connection! What am I doing wrong?
Max
Follow the video ( do 1 step at a time and confirm before you proceed to next level)
https://www.youtube.com/watch?v=9F54xZ3cJEE
BB
Thx for video! But I still cannot organize the stable operation of the switch! "Unable to connect 192.168.1.254". Connection not stable!
Max
unfortunatly nothing much i can assits here, since the Video is spoon feeding each step.
rather " "Unable to connect 192.168.1.254".
i would expect to explain the steps what you performed and what not working ? since we do not have any visibility, so try explain as much as details and steps what you have done, then we can figure out why it was not working.
Note : bare in mind, if your broadband router in same network 192.168.1.X you may have conflict.
BB
I'm new to networld, I want to apologize for that!
IP adress 192.168.1.2
Netmask 24
Gateway 192.168.1.20
Dns servers 8.8.8.8
Max
The truth is out there
IP adress 100.125.0.5
what is this IP your DSL router ? what is the IP address of Switch ?
BB
And after when I log in to web interface, I set ip configure "add.." to ip adress 100.125.0.5 and more different, connection is lost (Unable to connect).
Max
Do you have both IP configured as mentioned in the video ?
BB
my ip is 192.168.1.2
Netmask 24
"Do you have both IP configured as mentioned in the video ?" yes. when i configure ip. i press >>Ok(--This interface already has a dynamic IP address. Adding the static IP address will delete the dynamic IP address from this interface.--). after when i press Ok, switch is not responde and green LED stops blinking and stays on (DHCP IP address assigned).
 Max
Hello! I am still struggling with dhcp, my switch gets dhcp after I add ip adress in the web interface. When I configure stable access to the switch, can I write to you for further instructions on how to configure it?
Max
Google>> How to find IP address of switch   //// Is this the correct query to resolve my question?
Max
