Can't find info regarding Switch Upgrade Path anymore. Please help.
Daniel Dimkin
Hi Folks,
Sometimes I need to upgrade a Switch-IOS and a few months ago I was able to find Cisco infos/documets very easily.
Basicaly they described the upgrade path e.g. 12.0 -> 12.1 -> and finaly 12.2 (this is just an example). It was a Cisco document containing simple tables with the recommended upgrade paths.
Today I've been googling for the last two hours and found nothing.
Could someone point me to those documents please?
Thank you very much!
Daniel
Reza Sharifi
What type of switch are you trying to upgrade?
Hi, thanks for your answer - right now I have to upgrade a 2960 non PoE Switch. IOS Version is 12.2(something.. not in the office right now) in order to get ip routing working.
BR!
I am again in the office and the version of the switch is:
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE2, RELEASE SOFTWARE (fc1)
Daniel Dimkin
Problem is partly solved - I still can't find the docs I used before but it is also written in the release notes.
Thank you!!
