Can't ping HSRP from Nexus Device
Dear All,
I don't know why but I can't ping the HSRP address 10.xx.xx.1 from BIO-N5K-22 and LIMS on the right side (see diagram in attachment). All other device are correct (ping ok)
VLAN 200
N5K-11: 10.xxx.xxx.2 (HSRP listen)
N5K-12: 10.xxx.xxx.3 (HSRP master 10.x.x.1)
N5K-21: 10.xxx.xxx.4 (HSRP bck)
N5K-22: 10.xxx.xxx.5 (HSRP Listen)
LIMS (Catalyst 3750x in level 2)
The network is in dual-homed with 2 peer-link (& keep-alive)between each device in the same room (11<-->12 and 21 <-->22). I checked all level 2 (vlan, interconnection, ....). I used the fabricpath mode for my vlans. I'm wondering if there is a problem with my configuration from my nexus.
Could you tell me if you have any idea ? I can give you more information if needed.
Thanks for your help.
ranraju
hi m.durieux,
Can you share the following outputs from all the switches. You can attach the files separately for each device.
1. show run int vlan 200
2. show mac address-table vlan 200
3. show spanning-tree vlan 200
Ranganath
Hi Ranraju,
Here's you find attached my files with outputs. Actually, I'm using the vlan 568 for your information.
