Can't reach my local machine :(
JackStrong93
Dear Guys,
I've created a tiny server with http site. Machine communicates by wifi with my ruter, which assigns it a local IP.
Everything works smooth, via local IP, I can access it, no problem, site works.
Now I want to access it from an internet.
So I set up NAT Virtual Server. For chosen port 80, it suppose to redirect me to local IP machine.
I know my external IP. I put it into my browser :80, and connection is refused.
Additionally, I set Address Mapping(my external IP->local machine, local IP).
Still sucks...
Can you help me out? I've runned out of ideas :/
--> So I set up NAT Virtual Server. For chosen port 80, it suppose to redirect me to local IP machine.
How did you set up the NAT ? What device are you using to connect to the Internet ?
Georg, I use Asmax ar904g ruter. I did it using built-in software. For protocol type TCP, I filled LAN IP Address (with local IP of my server), then LAN port and PUBLIC port i set to 80, and enabled it.
Regarding Address Mapping: filled Global IP ( with the one checked at dedicated site like whatsmyIP.com) is transformed as virtual IP (local IP of my server)
