Vlan issue after ios upgrade
LIBJCFPL
I recently upgraded the IOS of a Cisco Catalyst 3650 to Fuji-16.9.4. Ever since the upgrade, the vlan keeps going up and down. This is a display of the log:
*Dec 24 02:33:44.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*Dec 24 02:33:45.463: %LINK-3-UPDOWN: Interface Vlan15, changed state to down
*Dec 24 02:33:45.470: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.1 (Vlan15) is down: interface down
*Dec 24 02:33:46.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan15, changed state to down
*Dec 24 02:33:47.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to up
*Dec 24 02:34:18.799: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*Dec 24 02:34:21.856: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to up
*Dec 24 02:34:52.859: %LINK-3-UPDOWN: Interface Vlan15, changed state to up
*Dec 24 02:34:53.860: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan15, changed state to up
*Dec 24 02:34:54.096: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.1 (Vlan15) is up: new adjacency
*Dec 24 02:35:10.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to down
*Dec 24 02:35:11.688: %LINK-3-UPDOWN: Interface Vlan15, changed state to down
*Dec 24 02:35:11.694: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.1 (Vlan15) is down: interface down
*Dec 24 02:35:12.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan15, changed state to down
*Dec 24 02:35:13.740: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/1/2, changed state to up
*Dec 24 02:35:44.745: %LINK-3-UPDOWN: Interface Vlan15, changed state to up
*Dec 24 02:35:45.746: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan15, changed state to up
*Dec 24 02:35:46.858: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.1 (Vlan15) is up: new adjacency
These are the settings related on the interface and the vlan:
interface GigabitEthernet1/1/2
switchport trunk allowed vlan 15
switchport mode trunk
speed nonegotiate
interface Vlan1
ip address 10.10.36.1 255.255.254.0
ip helper-address 10.10.4.30
ip helper-address 10.10.4.32
interface Vlan15
ip address 172.18.5.2 255.255.255.0
router eigrp JCL-EIGRP
router eigrp JCPL-EIGRP
address-family ipv4 unicast autonomous-system 100
topology base
exit-af-topology
network 10.10.36.1 0.0.0.0
network 172.18.5.2 0.0.0.0
exit-address-family
Is there anywhere I should be looking at?
16 Replies 16
ngkin2010
Level 7
Level 7
The SVI (interface VLAN15) will UP only if there is any physical port (either access or trunk) that belong to VLAN15 is UP.
E.g. if GigabitEthernet1/1/2 is the only interface that belong to VLAN15, when Gi1/1/2 go down, the SVI will down afterward.
Could you issue "show vlan" and "show interface trunk" to double verify?
This is what I get from the commands
MARION-3650-24#sh vlan
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/9, Gi1/0/10, Gi1/0/11, Gi1/0/12, Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17
Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21, Gi1/0/22, Gi1/0/23, Gi1/0/24, Gi1/1/1, Gi1/1/3, Gi1/1/4
15 EVPL-VLAN active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
3179 MARION active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
15 enet 100015 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
3179 enet 103179 1500 - - - - - 0 0
Remote SPAN VLANs
Primary Secondary Type Ports
MARION-3650-24#sh int
MARION-3650-24#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi1/1/2 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/1/2 15
Port Vlans allowed and active in management domain
Gi1/1/2 15
Port Vlans in spanning tree forwarding state and not pruned
Gi1/1/2 15
MARION-3650-24#
Reboot the switch again.
I have rebooted the switch and the issue is still there.
Good.
Now go find out what that downstream client. Maybe that requires a reboot?
Rebooted the 4500 and issue still exists. This is what I see in the logs:
*Dec 24 19:16:09.635: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.6.2 (Vlan74) is down: holding time expired
*Dec 24 19:16:09.943: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is down: holding time expired
*Dec 24 19:16:32.802: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is up: new adjacency
*Dec 24 19:16:33.458: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.6.2 (Vlan74) is up: new adjacency
*Dec 24 19:17:07.383: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is down: holding time expired
*Dec 24 19:17:30.683: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is up: new adjacency
*Dec 24 19:17:50.803: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is down: holding time expired
Hold on ... a 4500 on the other end?
Post the complete output to the command "sh interface Gi1/1/2)".
Post the complete output to the same command on the 4500.
I want to see what is going on why the EIGRP keeps flapping.
This is an EVPL with Verizon. The gigabit interface is connected to a canoga box, which in turn is connected to the 4500. Below is the result:
MARION-3650-24#sh int gi1/1/2
GigabitEthernet1/1/2 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 00f6.63f6.f61a (bia 00f6.63f6.f61a)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 254/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseSX SFP
input flow-control is on, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 2000 bits/sec, 3 packets/sec
5 minute output rate 3000 bits/sec, 2 packets/sec
202958 packets input, 48915417 bytes, 0 no buffer
Received 10888 broadcasts (10888 multicasts)
2393 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 10888 multicast, 0 pause input
191143 packets output, 42505404 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
For the 4500, this is what is on my config:
interface TenGigabitEthernet1/1
description ** Connection to NJRoom **
interface TenGigabitEthernet1/2
description ** Connection to GovDocs **
interface TenGigabitEthernet1/3
description ** Connection to Lending **
interface TenGigabitEthernet1/4
description ** Connection to Reference **
interface TenGigabitEthernet1/5
description ** Connection to ChildRoom **
interface TenGigabitEthernet1/6
description ** Connection to Literacy **
interface TenGigabitEthernet1/7
description ** Connection to TechServ **
interface TenGigabitEthernet1/8
interface TenGigabitEthernet1/9
interface TenGigabitEthernet1/10
interface TenGigabitEthernet1/11
switchport trunk allowed vlan 1,11,13-15,42,71,74,76,168,170
interface TenGigabitEthernet1/12
interface TenGigabitEthernet1/13
switchport mode access
interface TenGigabitEthernet1/14
interface TenGigabitEthernet1/15
switchport trunk allowed vlan 11,13-15,42,71,74,76,168,170
interface TenGigabitEthernet1/16
interface TenGigabitEthernet2/1
shutdown
spanning-tree portfast
interface TenGigabitEthernet2/2
shutdown
interface TenGigabitEthernet2/3
shutdown
interface TenGigabitEthernet2/4
shutdown
interface TenGigabitEthernet2/5
shutdown
interface TenGigabitEthernet2/6
shutdown
interface TenGigabitEthernet2/7
shutdown
interface TenGigabitEthernet2/8
switchport trunk allowed vlan 11,13-15,71,74,76,168,170
interface Vlan1
ip address 10.10.4.5 255.255.254.0
interface Vlan11
ip address 172.18.1.1 255.255.255.0
interface Vlan13
ip address 172.18.2.1 255.255.255.0
interface Vlan14
ip address 172.18.4.1 255.255.255.0
interface Vlan15
ip address 172.18.5.1 255.255.255.0
interface Vlan42
ip address 172.18.9.1 255.255.255.0
interface Vlan71
ip address 172.18.3.1 255.255.255.0
interface Vlan74
ip address 172.18.6.1 255.255.255.0
interface Vlan76
ip address 172.18.8.1 255.255.255.0
interface Vlan168
no ip address
shutdown
interface Vlan170
ip address 172.18.7.1 255.255.255.0
topology base
exit-af-topology
network 10.10.4.1 0.0.0.0
network 10.10.4.5 0.0.0.0
network 172.18.1.1 0.0.0.0
network 172.18.2.1 0.0.0.0
network 172.18.3.1 0.0.0.0
network 172.18.4.1 0.0.0.0
network 172.18.5.1 0.0.0.0
network 172.18.6.1 0.0.0.0
network 172.18.7.1 0.0.0.0
network 172.18.8.1 0.0.0.0
network 172.18.9.1 0.0.0.0
exit-address-family
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.10.4.2
@LIBJCFPL wrote:
reliability 254/255
Layer 1 issue.
balaji.bandi
As per the Logs the Port going up and down. to confirm waht is wrong ?
1.have you checked physical cable, make sure they are intact, (worth checking)
2. After upgrade, is the switch rebooted ? is this single switch or stack ?
3. what is the device connected otehr side  to GigabitEthernet1/1/2 ? do you see any logs other side ?
can you post below output
show version
show switch
BB
1. Physical cable has been checked and replaced.
2. Switch has been rebooted after upgrade. Single switch.
3. It is connected to a 4500. This is what I see on it:
Dec 24 07:34:30.346: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is up: new adjacency
*Dec 24 07:34:30.346: EIGRP: Enqueueing UPDATE on Vl15 - paklen 0 nbr 172.18.5.2 tid 0 iidbQ un/rely 0/1 peerQ un/rely 0/0
*Dec 24 07:34:30.348: EIGRP: Requeued unicast on Vlan15
*Dec 24 07:34:30.351: EIGRP: Sending UPDATE on Vl15 - paklen 0 nbr 172.18.5.2 tid 0
*Dec 24 07:34:30.351: AS 100, Flags 0x1:(INIT), Seq 23780/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:32.352: EIGRP: Sending UPDATE on Vl15 - paklen 0 nbr 172.18.5.2, retry 1, RTO 3000 tid 0
*Dec 24 07:34:32.353: AS 100, Flags 0x1:(INIT), Seq 23780/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:35.337: EIGRP: Received UPDATE on Vl15 - paklen 0 nbr 172.18.5.2
*Dec 24 07:34:35.337: AS 100, Flags 0x1:(INIT), Seq 2211/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:35.352: EIGRP: Sending UPDATE on Vl15 - paklen 0 nbr 172.18.5.2, retry 2, RTO 4500 tid 0
*Dec 24 07:34:35.353: AS 100, Flags 0x1:(INIT), Seq 23780/2211 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:35.356: EIGRP: Received UPDATE on Vl15 - paklen 44 nbr 172.18.5.2
*Dec 24 07:34:35.356: AS 100, Flags 0x8:(EOT), Seq 2212/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:35.360: EIGRP: Received ACK on Vl15 - paklen 0 nbr 172.18.5.2
*Dec 24 07:34:35.360: AS 100, Flags 0x0:(NULL), Seq 0/23780 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/1
*Dec 24 07:34:35.361: EIGRP: Enqueueing UPDATE on Vl15 - paklen 0 tid 0 iidbQ un/rely 0/1 serno 1-2349
*Dec 24 07:34:35.363: EIGRP: Sending UPDATE on Vl15 - paklen 793 tid 0
*Dec 24 07:34:35.364: AS 100, Flags 0x0:(NULL), Seq 23781/0 interfaceQ 0/0 iidbQ un/rely 0/0 serno 1-2349Dec 24 07:34:30.346: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 172.18.5.2 (Vlan15) is up: new adjacency
MARION-3650-24#sh ver
Cisco IOS XE Software, Version 16.09.04
Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.9.4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 22-Aug-19 17:33 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.56, RELEASE SOFTWARE (P)
MARION-3650-24 uptime is 20 hours, 57 minutes
Uptime for this control processor is 21 hours, 0 minutes
System returned to ROM by Reload command
System image file is "flash:cat3k_caa-universalk9.16.09.04.SPA.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
ipservicesk9 Smart License ipservicesk9
None Subscription Smart License None
Smart Licensing Status: UNREGISTERED/EVAL MODE
cisco WS-C3650-24PS (MIPS) processor (revision K0) with 832441K/6147K bytes of memory.
Processor board ID FDO2024Q027
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 00:f6:63:f6:f6:00
Motherboard Assembly Number : 73-15899-05
Motherboard Serial Number : FDO20232KX1
Model Revision Number : K0
Motherboard Revision Number : B0
Model Number : WS-C3650-24PS
System Serial Number : FDO2024Q027
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24PS 16.9.4 CAT3K_CAA-UNIVERSALK9 BUNDLE
Configuration register is 0x102
MARION-3650-24#sh switch
Switch/Stack Mac Address : 00f6.63f6.f600 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 00f6.63f6.f600 1 V03 Ready
Kavin Patel
It looks like interface VLAN 15 might keep on going down. I would suggest to take a look at that interface and enter the commands
int VLAN 15
autostate exclude
no shutdown
Which will keep it always up regardless of any ports in VLAN 15 being up or not
Also, I noticed that only VLAN 15 is allowed on the trunk. I would suggest to allow VLAN 1 also, as some protocols still use VLAN 1 such as CDP etc.
So check and see after allowing VLAN 1 on that interface and keeping it up.
Do you mean: switchport auto-state exclude
Am unable to input autostate exclude
