can't using ip routing in 3750x 24t -l
chenyizhen
Why can not I do with ‘’ip routing" and static route in 3750x 24t -l.
can you help me to solve this problem ,thans!!
12 Replies 12
Leo Laohoo
Post the output:  sh license
You can't enable IP Routing because you haven't accepted the EULA.
PS:  Please don't post screenshots.  Use cut-and-paste.
Hi Leo,
I have the same issue. I accepted the EULA as suggested, using  the "license boot level ipservices". Switch restarted and then I was  able to  issue the "ip routing" command, however when I changed it back  to level lanbase then no ip routing command.
Any ideas?
See below the output of show license after "enabling" ip services.
DCSG-PENROSE-DC#show lic
DCSG-PENROSE-DC#show license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, In Use
        License Priority: Low
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Priority: Medium
Murilo
"ip routing" is only available with IP Services feature set. This is why when you went back to LAN Base or IP Base, the command is disabled.
Sent from Cisco Technical Support Nintendo App
Thanks Leo. I think you are right.
I guess something wrong with this document then.
High-Performance IP Routing
Cisco  Express Forwarding hardware routing architecture delivers extremely  high-performance IP routing in the Cisco Catalyst 3750-X and 3560-X  Series Switches.
• Static routing (16 routes) with LAN Base feature set.
But then also this on the same document
Cisco Catalyst 3750-X and 3560-X Series Software
In  addition to IP Base and IP Services feature sets, the Cisco Catalyst  3750-X and 3560-X Series come with a new LAN Base feature set. The three  feature sets available with all Cisco Catalyst 3750-X and 3560-X Series  Switches are:
• LAN Base: enterprise access Layer 2 switching features
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
And exactly what routing protocols are you planning to use?
Just static routes but I think you were correct on your first statement, LAN base is only a layer2.
Don't think LAN base supports "16 static" routes.
According to the configuration guide:http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/configuration/guide/swiprout.html#wp1118518
Starting with Cisco IOS Release 12.2(58)SE, switches running the LAN base image support 16 user-configured static routes on SVIs. Static routing configuration is supported on the LAN base image only with the default SDM template and only on SVI interfaces. No routing protocols are supported.
Hope this helps..
Awesome. Thanks for that....looks like an IOS upgrade.
Was running 12.2(55)SE8
muca what you have done with this issue i've the same issue
Read this.
Please don't forget to rate our useful posts.
