Can TACACS+ and Radius coexist on the same Switch
Ibrahim Jamil
Level 6
Level 6
Hi Guys
Can TACACS+ and Radius coexist on the same Switch , TACACS+ for decice Aministration while Radius for Dot1x And MAB Operations
thanks
balaji.bandi
yes, you can have both presents in the switch.
BB
JimWicks
Yes, you define a seperate server-group for each and then reference those in the aaa method-list so looks something like:-
aaa group server tacacs+ Mgmt
    server 10.1.1.1
aaa group server radius dot1x-authentication
    server 10.1.1.2
aaa authentication login vty-mgmt group Mgmt local      <-- reference "vty-mgmt" under your VTY config.
aaa authorization exec mty-mgmt group Mgmt if-authenticated   <-- reference "vty-mgmt" under your VTY config.
<include lines here for command authorization and accounting via T+ pointing to the correct aaa-server-group>
snip.....
aaa authentication dot1x dot1x-Clients group dot1x-authentication   <-- reference "dot1x-Clients" where you need to use dot1x + Radius.
