Can we connect 1 gb fiber cable to 10 gb ethernet port ?
v4meet999
I want to connect 1 gb fiber cable to 10 gb ethernet port. Please advise what else is required ?
5 Replies 5
Giuseppe Larosa
Hello v4meet999,
the answer is negative:   a 1Gbps device cannot be connected to a 10 Gbps port, because the latter cannot slow down to 1Gbps.
In some specific cases like for Cisco 4900M or other switches a twingig converter can be installed in a 10GE port and one 1SFP optic can be installed  into the twingig converter.
see
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbee3.html
Hope to help
Giuseppe
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Some of the newer 10g ports are SFP+, which often means they will support gig or 10g depending on SPF.
I have 3750-E switch and 2 ten gigabit ethernet ports for uplink. I want to connect another 3750-E switch with 1 gb fiber link.
Disclaimer
Posting
For a 3750-E, you may use the TwinGig, as described by Giuseppe.
See: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbee3_ps7078_Products_Data_Sheet.html
TwinGig converter.
When you buy a 3560E/3750E, you will get two TwinGig coverter for free.
If not, e-bay.
