Can we mix power supplies of different wattage on 6500 ?
osama.sisan
I have 6500 core switch with 2500W power supply, and I want to install a second power supply with 3000W ? is this applicable ? if yes, is there a specific configuration that must be done ? Thanks
Best Regards,
Osama
Leo Laohoo
No extra configuration needed but are you running PoE?
Check out the Cisco Power Calculator.
So is it applicable ? I can have a mix of 2500 and 3000 ? and Yes I am running PoE.
Does it affect anything ?
PoE?  How many PoE line cards (specify the model number and the quanty)?
Like I said, learn how to use the Cisco Power Calculator.
Dennis Goh
I just experienced the same scenario. Here is what I found out:
Table 13-1 from http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/15.1SY/config_guide/sup720/power.html#wp1020384
To make this work, here are the steps:
  • •1.    Configure combined mode (redundancy disabled). Command: power redundancy-mode combined
  • •2.    Insert 3000W PSU.
