3750X output drop
burak-isiksoy
Hi All,
I have a 3750X stack with 2 members running 15.0(1)SE3
Strange thing is I am getting discard errors on some of the second member switch ports.
Problem is this ports is used for just management connections and there is almost no utilization.
And it gets weirder when I issue sh inter gx/x/x continuously i get same counts for total drop even if i clear the counters
956 or 0
I tried shutting down the interfaces rebooting the member.
Any ideas what could it be ?
here is some output about;
interface GigabitEthernet2/0/40
description HP_ILO
switchport access vlan 110
switchport mode access
end
Filanco-3750x#sh int Gi2/0/40
GigabitEthernet2/0/40 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e4d3.f10c.8aa8 (bia e4d3.f10c.8aa8)
  Description: HP_ILO
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:38, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 956
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     7899 packets input, 6109595 bytes, 0 no buffer
     Received 12 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     4435172 packets output, 379348718 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Filanco-3750x#
BR
Burak
sgouldbo
You might be hitting bug:
CSCtq86186 (Catalyst 3750-X and 3750-E switches)
In a switch stack, the show interface command shows incorrect values for output drops.
The workaround is to use the show platform port-asic stats drops command to see the correct values.
This is fixed in IOS 15.0(2)SE and later.
Hope this helps.
sgouldbo
Hope this helps.
hi,
this is exactly what it is. thanks for the help.
BR
Burak
