05-18-2016
04:55 PM
- last edited on
03-25-2019
04:38 PM
by
ciscomoderator
Hi Team,
can anyone advise whether we can stack both cisco 3750X and cisco 3750G switches together?
Suthakar
05-18-2016 05:05 PM
Yes you can mix the hardware but please read this doc as it is feature set related too
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_58_se/configuration/guide/3750xscg/swstack.pdf
Alex
05-18-2016 05:11 PM
Hi Alex,
Thank you for the prompt response, I guess I had a glance through this doco before, but its does not have any reference to 3750G's in particular ? A'm I missing something here ?
Regards.
Suthakar
05-19-2016 05:07 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You can stack any of the various 3750 model series together.
There are conditions to doing so, and "gotchas". For example, stacked member unit IOS software has to support, I recall, the same major stack version. The easiest way to insure that, have the same IOS version on all the stack members.
Some of the "gotchas" include, the 3750G-12S supports SDM templates unique to its model only (i.e. you need to insure it runs "common" SDM templates if being used with other than similar models), StackWisePlus loses many of its Plus features when stacked with StackWise units (such as will happen stacking a 3750G with a 3750X), if stack master has a feature set not installed on other stack members, failure of the stack master will cause the stack to "lose" active features.
BTW, mixed stacks are also a pain to upgrade.
