cannot connect to internet after setting up the VLAN
devpatel87
After configuring VLAN i am not able to ping to the router 192.168.1.2 from any of the pc.please see the cisco 3560 configuration.and attached pkt file for diagnose the issue.due to this issue i am not able to connect to the internet in my real scenario.please help
Switch#show running-config
Building configuration...
Current configuration : 1930 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip dhcp pool dev
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.1.1
ip dhcp pool QA
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool CS
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
ip routing
no ip domain-lookup
spanning-tree mode rapid-pvst
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 30
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
no switchport
duplex auto
speed auto
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.2
line con 0
line aux 0
line vty 0 4
login
end
glen.grant
   Does the device at 192.168.1.2 have statics pointing back in for those subnets?  Also usually ping is blocked on a FW .
rizwanr74
Level 7
Level 7
Hi Devendrakumar,
Please check on your router that supposedly doing the Nat tranlsation for your inside subnets has static-route point to back to switch's interface address 192.168.1.1.
thanks
Rizwan Rafeek.
