Cannot create VLAN other than default in Cisco 2960-X switches
Dread33
I need to use VLAN 3200 and 3201 in my network. But i cannot create these VLAN's in Catalyst 2960-X series switches. What shall i need to do.
the version is as:
cisco WS-C2960X-24TS-L (APM86XXX) processor (revision S0) with 524288K bytes of memory.
Processor board ID FCW2241B3L5
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 70:35:09:D9:E8:00
Motherboard assembly number : 73-16695-05
Power supply part number : 341-0529-02
Motherboard serial number : FOC22390DSS
Power supply serial number : DCB223150LU
Model revision number : S0
Motherboard revision number : C0
Model number : WS-C2960X-24TS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC224039SF
System serial number : FCW2241B3L5
Top Assembly Part Number : 68-100473-02
Top Assembly Revision Number : H0
Version ID : V05
CLEI Code Number : CMMMU00ARD
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24TS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
Configuration register is 0xF
you also might need to configure the extended system ID:
Switch(config)#vtp mode transparent
Switch(config)#spanning-tree extend system-id
prefixlength
Hi :)
What VTP mode is the switch currently operating at?
VLANs in the extended range (from 1006 to 4094) can be only be created while the switch is in VTP transparent mode.
Hello
on a side note - Check the internal usage of the switch system vlans it could be possible that vlan it's already being used by the switch especially if this usage is set in a descending order
sh vlan internal usage
lastly what sdm template is running
sh sdm prefer
Kind Regards
Paul
