Hybrid port configuration
Cisco Catalyst 2960PD-8TT-L Compact Switch
I want this switch Gig port perform as access and trunk port same time.
Can anyone tell me how to do it?
8 Replies 8
Mark Elsen
 - Not possible
   M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
What is the use case here, explain more, there may be another option can be suggested here based on the requirement.
Why do you think you need access and trunk port on the same port?
BB
Ditto.
Define how you see a port being access and trunk at same time.
BTW, a port with a defined voice VLAN, might be much what you desire. The voice VLAN doesn't need to be used for voice traffic.
Here is the need.
Port 1 to 6 will access under VLAN-20 ( Untagged )
Port 7 & 8 will pass the VLAN-20 as ( Tagged ), and those port will be the member of vlan 10 which will Untagged.
And Vlan 10 will the manage VLAN.
You can refer to below config:
vlan 10
name Manage-Vlan
vlan 20
interface range gi0/1-6
switchport mode access
switchport access vlan 20
interface range gi0/7-8
switchport mode trunk
switchport trunk allowed vlan 20
switchport trunk native vlan 10
interface vlan 10 ( created for management purpose )
ip address x.x.x.x x.x.x.x
hope above is helpful for you
Let me check and i will reply to you ASAP.
Configure 1-6 as Access port belong to VLAN 20 - that only for pure VLAN 20 - so you should have Layer 3 SVI some where in the uplink port for that VLAN 20.
Regarding V
Regarding Port 7 and 8, where is this connected to? explain more to understand here?
BB
Muhammad Awais Khan
If you have some specific requirement where switch is connected to another L2/L3 device or IP Phone/Wireless, then you can configure Native Vlan in addition to the trunk configuration on that interface.
A trunk port configured with 802.1Q tagging receive both tagged and un-tagged traffic. By default, switch forwards the un-tagged traffic configured in native vlan for the port or interface. The default native vlan is 1 which you can modify.
Ref: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/vlan/configuration_guide/b_vlan_152ex_2960-x_cg/b_vlan_152ex_2960-x_cg_chapter_0100.html
