cannot ping 2 computers are connecting to the same catalyst 2950 SW
nesreenbogh
cannot ping 2 computers are connecting to the same catalyst 2950 SW and both in the same network? help please
hi,
are both PC using same IP address/subnet?
make sure ping/icmp is enabled on both PC and try to temporarily disable windows firewall or third party FW.
5 Replies 5
Joseph W. Doherty
Same VLAN?
Computers don't have firewalls?
yes all ports on VLAN 1 and no fire walls on the computers and also tried different ports because the switch is old and used but it didn't work
Can you share the ipconfig /all of both PCs and the config of the switch?
hi,
Is it possible to directly connect both switches to each other using a cross over cable?  Such a test could exclude switch as a cause of the problem.
