cannot ping between switch loopback interfaces
fran19422
Level 3
Level 3
Hello, I have configured two switches with loopback interfaces (both on same subnet). The two switches are connected with a trunk. Why can I not ping between these two switches (loopback addresses). Are loopback interfaces on switches not supposed to be used this way ?
Thanks for any info.
mhnedirli
Level 3
Level 3
What is your switches and how did you configured, can you share configuration. You can configure as below with vlan interfaces. You can not ping loopback interfaces you need to add route for loopback interfaces.
SW1
int vlan 1
 ip add 1.1.1.1 255.255.255.252
SW2
int vlan 1
 ip add 1.1.1.2 255.255.255.252
